This may (Or may not) be an absurd question but, I was wondering if remastered vinyl could be considered true analog since some parts of the 'remaster' are done digitally?
I have noticed some original pressings sound quite amazing, when in NM condition and on a decent turntable and Cart. And I know there has been some debate on certain records, whether the original pressings or remasters sound better.
So in examining this, I have recently started to wonder if, when buying albums that came out in the Era of vinyl, I should try to stick with NM or EX copies of original pressings or if the audiophiles give the go ahead to grab the remasters?
Specifically I want the full Analog experience to the greatest degree possible.
What's everyone's thoughts?
Good question but so difficult to answer. What a web of variables has been created in the process.
First, it helps to remember that "mastering" in this sense is the signal processing required to get the material in form to make a lacquer as part of the process of vinyl pressing. Mastering the cutting of the lacquer is an art form since the cutting was so critical in how the final product will sound given a multitude of compromises required.
In theory, the abilities of tape to preserve a better facsimile of the original performance was far better than vinyl when vinyl was the primary means of delivery. At least under the commercial requirements of the music business. So, there was typically the need by the mastering engineer to significantly manipulate the sound on the tape coming out of the tracking/mixing process before use in cutting the lacquer.
Does it then follow that an all-analog chain will be better in sound quality than a process that has some A-to-D-to-A link in the chain? I say no.
Recordings in the 50's and into the 60's on mono, or 2/3 channel recorders, were often mixed and processed "live" meaning that the balances were set prior to tracking of the individual cuts live in the studio. Maybe vocals could be punched in over the instrumental track. As time moved on producers and engineers became more creative in the ability to virtually add recording channels by recording bits of the performance and then record that performance down to one channel of new recording reserving the other 2 or 3 channels to record additional performances.
I recently read where the process of recording at Motown Records started with basic rhythm tracks. There was no equalization or processing at all in the tracking process. Then this "A" tape would be recorded down to a channel on tape "B" with any signal processing added along the way. This would continue to tapes C, D, E, F etc, as needed. So, with each iteration there is some amount of taping the noise and distortion elements into the next mix. The point is by the time the final mix is achieved you are working on 5 or more generations of re-recorded tracks going into the vinyl master tape. Is this final mix up to the potential of audiophile expectations for analog sound? No, but this is not to denigrate the engineers efforts which was more focused on getting out a viable commercial product.
Digital sources used for mastering a vinyl record- that is digital recording of the original performance- may seem totally contrary to the purpose of making an analog source for us to use. I get that. Why go to the trouble to convert digital source to vinyl? Or is it just taking advantage of audiophiles who want to justify the need to spin a disc. On the other hand, digital material can be manipulated and processed to an extent not allowed with analog without the kind of degradation you might find in the production of all-analog back in the day. Especially going well into the 70's when saved time meant saved dollars and the price of oil was playing havoc with vinyl costs.
So, as mentioned repeatedly already, we just can't assume all-analog will always be the better outcome.
