Are the Marantz AM antenna interchangable?
Aaron99
Another lost Marantz followed me home... This time it is a 2220B. I haven't gone through the internals yet, but the AM antenna is missing from the back. Do I need to source one from another 2220B or are they interchangeable between other models?
I did a random look at the service manuals for 6 or 7 different units, some B and some non-B. Every unit had a different part number for that antenna. The 2230/2245/2270 shared a part number. On all of the other units the part number was different in the last two digits. I can't say this means others won't fit, but in general, it seems Marantz uses the same part numbers between units if the part is the same.
As far as I know,the 'straight' bar AM antennae with the clamp come in two types, four wire and five wire.
Please excuse the crude drawing.
Tom
Tom
Thank you for your research Tom. I wasn't sure if I needed the exact part or if they were interchangeable. In my case I found the exact part on ebay. But this will probably help someone in the future....
