dshoaf
That high voltage buzz
I'd do the separate 9090's rather than the one Phase Linear. This is mainly due to the Phase Linear's relative dislike of low impedances. That's a large room so you'll need some power to get them cranking. Keep separate power amps on separate pairs to get the most out of it.
On placement:
- One pair would go along one wall as you normally would.
- The second pair would go along the side walls so that it makes a "U" shape relative to where you would sit/stand.
- Both left speakers to the left: one on the back wall, one facing the side wall
- Both right speakers to the right: one on the back wall, one facing the side wall
- The 2 left/right pairs should be placed equal distances away from the corner.
- The Vs will point toward the wall as usual for all 4 speakers. All speakers will need to be about 12" away from the wall for the best sound dispersion.
- Use a Y cable to have the equalizer drive the 9090s.
I tried to draw a text version of this but the thread removes all the spaces which jumbles it up. Hope that description works.
On hanging the speakers:
There should be some small dimples on the bottom of the cabinets on the outter edges where you can locate eye bolts for hanging. I used thick threaded versions and drilled pilot holes to get them threaded without splitting the cabinet since you're close to the edges.
I used chains for suspension so that I could adjust the back point up and down so you can focus the high frequency dispersion into where you'll be sitting/standing. I used S hooks to make them permanent.
Hang the speakers so that they're the same distance down from the ceiling as they would be sitting up from the floor. Then adjust the V end up or down for dispersion.
Cheers,
David
On placement:
Cheers,
David
And their VCS center channel sounds awful IMO.
