I've always found a wall shelf to be the first line of defense. I make them from 2 layers of 3/4mdf glued and screwed together, mounted on a couple of heavy wall brackets. For my sprung table (Oracle Delphi) there is nothing between the shelf and table. The MVSS tends to help with any other vibrations if any.
My other table is a Rega, also on a wall shelf, but this one has three raquetball balls using the footer cups and a cup under the ball. It decouples nicely and the elasticity of the balls helps stop any other vibration issues.
I've tried other methods, sand box with or without innertube, inner tube alone, various spikes, pucks rubber and nothing has worked any better than what I currently use for my tables in my house. YMMV.
