No, that's voltage, in Volt. But never mind...
Greetings from Munich!
Manfred / lini
Thanks! Fixed it, I think. Might not have needed that last bowl of herbal enhancement......
Manfred / lini
might not have needed it but it's always funThanks! Fixed it, I think. Might not have needed that last bowl of herbal enhancement......
No, they're older.
Yup. A watt is a watt is a watt.
Where things go off the rails is when the marketing dept gets a hold of the specs and scans it for the biggest number they can slap on the outside of the box.
I find the car audio field is the worst offender. You pick up a subwoofer and it may say "1200 watts!" or "1500 watts!" in big numbers on the box. Then you read down the small print on the side and find that's a "peak" number and the RMS watts are only 500 or 600....I find the practice of doing that "deceptive" at best, "greasy" at worst. But it's not false advertising, so they get around the laws with a little "creative" marketing....
Just musingI guess ...but trying to see if ohers feel vintage PUSHES harder than newThen why post a noob question![]()
Like men, back in the old days , WATTS were WATTS and Men were MEN ....LOLQuestion is, what does that mean? I.e., does that make those vintage watts wiser? More experienced? More sensible? Or rather slower? Grey-haired or bald? Toothless? A little drippy at times? Somewhat gnarly? "Get off my lawn!"-watts?
Grinnings from Munich!
Manfred / lini
Beautiful analogy!Actually, no, not in this situation. If you understand the differences between the FTC testing regimen and actual speaker demands, you get a far more accurate view of the world. When I did stand up trainings I would often as "what's faster, an Indy car or an F150?" Of course, everyone jumped on the Indy car bandwagon. I would follow with "off road". Game changed.
The answer to the OP's question is that the old Marantz amplifiers were designed to address real world speaker loads, the new product is designed to look good on the FTC power tests. Part of the downfall of the industry.
It's like the old horsepower wars. They used to rate an engine in the lab, with nothing attached. Now they rate them on a dyno. Wheels to the ground.
They used to rate watts at 1khz. An immediate impulse blast. Now they do RMS full frequency, all day long. Watts are watts. It's just a question of how you measure them.
I remember in the mid to late 70s noticing that you generally could not go past about 11 o'clock. Anything after that started distorting.
Nothing wrong with experimenting. Try the two receivers with the other pair of speakers to kind of make it a fair comparison.I hear what you are saying ..but please understand, I am not a noob. I am trying to point out there is a distinct difference in OOMPF on my 6 vintage amp (all rated at 30wpc or less) than the supposed 80wpc modern amp. So what I amy be finding is the Marantz SR4023 may just have inflated numbers. I'll report back when I do the swap and compare![]()
Didn't Stereo Review or one of the mags have some kind of power cube measurement to better show what an amp would do with real speakers?
could have been done to keep the loudness contour active for the same reason.thats a product of excessive gain. That seemed to be a "thing" for a while, make things super loud when the volume was just barely cracked. I suspect it was done to confuse power with gain. "Look how loud it is at only 9:00! Must be powerful!", when in reality it might be basically flat-out at that position on the control and anything beyond that just makes it clip harder.
I think all of my receivers are this way, tube and solid state. At least half of the volume control travel is not useful.
That is one of the reasons I gave up the old crap hunt and stared buying new for the main system, after living with new for awhile now $ for $ it was a great decision SQ wiseI think vintage watts are more expensive
