I knew a guy a long time ago who had an FR64S on an Ariston. Even though he lived in a concrete highrise, if you walked by the table, the suspension would bottom out lol. Sounded pretty good, but a bad mismatch weight-wise. The Ariston springs work better with a light arm, needless to say.
As to what looks good, it's a matter of preference. SME 3009/II probably qualifies....too bad it doesn't sound that great. Shure V15-V with a Jico stylus is probably the best option, or maybe a Denon DL-304. Anything with a stiffer suspension will shake the arm to bits with its flimsy cheese grater shell and knife edge bearing.
My vote would be for a a Mission 774 original, but looks might be an issue. Even though the 774 is low mass, with the damping trough and appropriate paddle, the design is robust enough it can accomodate the stiffer suspensions found in today's cartridges. It sounds pretty good, too....much better than the RB250, even with the Michell mods.
https://www.vinylengine.com/tonearm_reviews.php?make=Mission&model=774+(original)
