Article entitled "Inaudible High-Frequency Sounds Affect Brain Activity"
guiller
Toscaninichus Australis
Surfacing through the internet I´ve came across this article:
http://www.arraytherapeutic.com/library/articles/JN83-6-3548.pdf
I am unable to judge anything about the quality of the authors or the claims stated in this paper, but I´ve found the content at least provocative and amusing and therefore it is perhaps worthwhile of sharing it with some fellow AKers.
All the best
PS: sorry if this is a repost
It isn't new, but it is controversial:
http://en.wikipedia.org/wiki/Hypersonic_effect
A very relevant quote:
System non-linearities (present to varying degrees in all audio reproduction electronics, speakers, etc.) are known to produce lower-frequency intermodulation products when the system is stimulated with high frequency signals.
Whenever a speaker is fed a frequency, it will also produce other frequencies above and below that frequency (which is distortion). Since some are below, you will often get audible frequency distortion from a frequency that is not itself audible. You can also do the same thing at the low end of the audio spectrum, by feeding a frequency too low to be audible to a speaker, which will also produce higher frequencies than what is fed to it, which are in the audible range.
That must be the reason why FM is so good to listen to when you feel like you're going insane. Less inaudible high-frequency sounds. :yes:
