Russellc makes some very great points with respect to various mods. And, once again, if I had an 80s AR TT, I would go full throttle with as many mods as possible. This includes a lead platter despite the debate. The lead platter on my buddy's ETL-1 is insane, so are all the other Scillia mods. Killer TT to die for, and (again my opinion) it puts an LP-12 to shame.
Ok, now back to the XA.
There are no cons to upgrading the springs, please excuse my earlier remark in saying that there were pros &
cons... Yes, it could be nice to have more easily adjustable springs, but the stock springs are easy enough to adjust. Plus, if you plan on using a heavy clamp on the XA, you should actually be buying another TT. The reasoning here is that the Hayden motor is not a big fan of the extra strain imposed upon it with a heavy clamp. With that said, you still can use a clamp, just not a very heavy one. And, adjusting the springs for this extra weight is easy enough. I highly recommend that you use multiple excellent-quality bubble levels and a straightedge level to do the job accurately.
You could modify the arm board and platter chassis so that you could use your arm of choice, etc, but... It's an XA or TA, and in the end, the XA, TA & XB are wholly unique & simple beasts. They work wonderfully in stock form once set up properly. In fact, they could quite possibly run forever if the proper maintenance is fulfilled.
You could improve certain aspects of the XA/TA/XB such as removing the Delrin damping on the arm, adjust the overhang properly, lube up that platter bearing and tone arm pivot, balance the platter, adjust springs, remove spring foam, slap Dynamat or any other anti-resonant material under the plinth, add your choice of new isolation feet, a slab of marble under the feet with more isolation feet, remove the particle board bottom, rewire the arm, add gold-tipped RCA connectors, etc...
Get yourself an excellent cartridge, too. It seems like the XA prefers Shure cartridges. A V15 VxMR will make your jaw drop on this TT. So would a M-91ED or a M97xE.
By the way Russellc, my next purchase is an 80s AR TT once again
Cheers, gentlemen.
The timeless simplicity & elegance of the XA is a wonder in this day and age...
