33&athird
Turn on & Tune in
Hey all, I recently bought a sx-727 from e-pray (I know, I know), and surprisingly, it arrived safely. I paid somewhere around what I belive to be fair-market value (including shipping), and that's not a big deal, I never get scores or whatever to brag about. The problem comes from the unit itself.
Cosmetically its around at least 9.5/10, everything is mint (minus some dust), and everything is original...hasn't been touched in 37 years...and thats the problem. The left channel appears to be working (as far as amplifing), since when switched to mono, both play through the speakers...but in normal mode, the left channel is absent. I had some luck moving buttons and switchs around to get the left working, but even then it was intermittant. I assume that deoxit would fix this, but being new to actually repairing units (my 525 was fine from the get-go), I want to be sure I get the right stuff.
The other concern is also over the 37-year old thing, the capacitors. I would like to recap it, and I downloaded the service manual to get the values. My father does not see the point of recapping, since "hes never replaced a cap for anything", But from what i've read, this could greatly improve sound. My 525 may need it to, but that can wait. The reason the re-cap came up is because the sx-727, from my inital listening (one channel out, bear in mind) was not a great improvement on the 525, maybe it shouldn't be...I did not know what to expect.
Now, as not to post a standard recap-deoxit thread, a different question; This was advertised as working/sounding great...So, this is false advertisment, and since I just now got it, I could potentially deal with it and get a different unit later. My dad belives this to be the correct course, although I think I wouldn't run across one in this overall condition for a long time. From what i've read, a re-cap is easy, once you sit down and work on it, and de-oxit is not too hard, but you have to remove some boards.
So, what do you guys think? any advise or opinions on this receiver?
I could explain things better, if need be, since I generally write in stream-of-consious, and it can be difficult to get the point across.
Thanks in advance for any information, or insight into what to do next.
