GlobalVision
I have a brand new turntable (AT LPW40WN) and a brand new receiver (Denon AVR750h) and when I hook it all up I have everything plugged into phono, ground connected, and have tried with the turntable's built in amp both on and off and cannot get the sound quality to play clearly. It sounds like it needs to be grounded and/or go through an amp but the problem is never solved with any of the configurations of the ground and amp on/off together.
Please help, pretty please. I'm going to take an audio sample and post that on here as well.
Audio File here - https://drive.google.com/file/d/1D2pJkdXDQx4NZPRsDKswQnrgqhZpgM7I/view?usp=sharing
You can hear the constant buzz in the background. Also, at this volume from another input source the music would be blaring loud instead of fairly quiet.
I have also tried using another turntable w/ the receiver and was met with the same issue. This second turntable has been successfully played with an older Yamaha receiver (90's RXV590) while also being connected through phono.
Final important detail - if the turntable is plugged in there is still feedback you can hear even w/out it playing a record, which is why I originally thought getting the ground in place would fix the issue.
