The aftermarket (Jico) shibata is bonded, but they're good quality. LpGear usually has a vivid line, but not for the AT15/20 body. This is one of the old round plug bodies. I wonder if an ATN14 would fit? They have a vivid line for that - $90. The ultimate would be a transplant, but that's expensive and hairy.
neo
neo: Nope, wouldn't - 'cause one the AT14Sa body the connector block is only about as wide as the generator shell, whereas on the AT15Sa/20SLa body the connector block is a bit wider, so that (the plastic holder of) the needles for these have to be wider on the inside towards the rear end. Well, and the other way around it would work either, because the ATN15/20 has higher side walls than the ATN13/14.
PA: I'd suggest to grab an ATN15XE instead.
Greetings from Munich!
Manfred / lini
I figured something like that. The Jico replacement for the XE is a .3 x .7 mil bonded/straight alum. cantilever for $40. Stereo Needles says they have an orig. .2 x .7 for $120.
Hardly seems worth the difference, even if it's a nudie. I suspect the Jico shibata will outperform the orig. XE?
Would a Clearaudio style trim even work with a round plug? I guess the magnet assembly would keep it from rotating, but it doesn't seem secure. It would be interesting to find out.
I think the best would be the Jico shibata and next would be the XE replacement.
neo
Thank you all for your answers, attracts me the needle lpgear 129 dlls, but for your comments, I can find the original, although it will not be easy to find. A needle m97xe SAS'd better at15sa? or I can also go through at44mlb?
