Sebastian A.
I'm a bit confused about the wire connections between the headshell in my AT-LP120-USB turntable and the AT440MLB that I just got. When I took out the headshell to replace the cartridge (which was the AT120E) I noticed that the cables were not going in a direct path but crossed, as you can see in this photo:
I installed that cartridge two years ago so I couldn't remember why I had done it that way. I searched online but I couldn't find anything concrete, and the headshell doesn't seem to have any letters or colors that indicate polarity. However, the manual for the AT440MLB shows it, and judging by it, the cables would have to be crossed, but it doesn't make too much sense to me:
I did connect it respecting the polarity, which turned out to be the same way that I had the previous one, but I just wanted to double check with the experts here, because I can't imagine why would the design call for the cables to be crossed between headshell and cartridge.
The few records I tried so far sound fine, but to test if the left and right channels are correct, I would have to find an album that I have in both vinyl and CD with a distinctive instrument or something else on either channel, and that would take me quite a while.
Unfortunately I don't have one of those audiophile test records with a guy saying "Left Channel, 1 Khz", and when I looked them up they were really expensive. So if someone could tell me if that's the way the cables are supposed to go I would really appreciate it.
Thanks.
Thanks.
