Hey everyone, just trying to find out more information on this cartridge I've recently installed on my turntable. My parents gave me their old JCPenny MCS 6502 belt drive tt. I'm trying to revamp it and make it work good as new again. I installed a AT91/AT3600 as per Turntableneedles helped me find. I have a few questions about this cartridge, but also about my stylus pressure on the record.
First off, I installed the AT91/AT3600 carbon fiber cartridge last night. It sounds great. The specs they gave me are as follows:
Stylus: .6mil Conical Bonded Diamond tip
Cantilever: Alloy round tube
Tracking Force: 1.5 - 2.5 grams
Output Level: 4.2mV @ 5cm/sec. @ 1Khz
Frequency Range: 20 - 20Khz
Load Impedance: 47K ohm
Channel Balance: 1.5 dB
Channel Seperation: 20dB @ 1Khz & 15dB @ 10Khz
http://www.turntableneedles.com/Cartridge-AT3600CF_p_690.html
My turntables specifies on that user manual that the balance weight for the tonearm is between 1.50g and 2.0g (literally 3 settings). The recommended pressure is 1.75g per the manual. With the new cartridge I have tried to get the stylus to raise up off the record at 2.0g on the balance weight and 0g on the bias knob, but has not worked. As you can see the tracking force for the stylus is between 1.5g and 2.5g. I basically want to make sure I'm not scratching my records or doing anything to harm that player/records. So I have set my bias to 1.75g and my balance weight to 1.75g, but wondering how to tell if it's actually working properly and on the right settings. Any tips or recommendations for what I can do? Thanks in advance!
