AT95e why does everyone love this?
"I do realize that the suspension may need to loosen up a bit more, but in my experience, the cartridge's sound will not change, its tracking might ( I didn't really hear any mis-tracking)."
this occurs with every new genuine stylus i've had for the 95e..probably 10 or more... give it ten hours solid run in on used records which will give the basic diamond profile a bit of *groove polishing* and allow the suspension to settle under load. Stick to the 2.0gm tracking force during this period..then back off 1/10th or so after run in...and the bass midrange and treble should balance out nicely. Male and female Vocals are a strong point of this cartridge as is the well centered and layered midrange and rock solid (if not quite the deepest) bass...treble will calm down and gain a bit more definition over initial sparkle after run in..but you will have to make tiny adjustments away from the recommended vta to get the treble to do what it can within it's limits. Uk hifi mags used to to suggest an optimum tracking force of 1.85gm to1.9gm depending on room temperature for the at95e long before the web made it so popular or manufacturer's recommended vta were considered the best place to settle instead of begin. (This is usually just a ball park figure with budget cartridges as they don;t know what arm you will use the cartridge in anyway).
I agree with earlier comments that the 95e will better an ortofon om10... From personal experience in a medium mass arm..it will also better a nagaaka mp11 (non boron) , it does bass scale , slam and attack and midrange body better than an at110e (which has more base 'note' resolution but not as much scale or weight, but it can't compare with the at110e as the cheapest cartridge I've used (at the time of manufacture) that can do a good 3d sound stage illusion on live , well miked recordings, or unlock a dense acoustic jazz recording and give you left middle right as well as front to back layering convincing enough to make you tinker with seating positions and speaker placement (room treatment.)
Give the at95e a chance though and I don't think it will feel like money wasted , even if you are used to a highly calibre stylus profile or a more exotic generator. My humble opinio regarding moving magnets is that adding a better stylus to the at95e is a good upgrade path unless you opt for something like the late 70s acutex tri-poles where even the humble elliptical stylus attached to such an advanced generator will make most modern (yet essentially basic) dual pole moving magnet designs seem a tad expensive regardless how fancy the diamond facets are cut.
Its compliance number is 11. I asked AT about this a few days ago and got my answer yesterday. I'm fine at 2.125 grams.
ah ok..is that dynamic or static? another thing to bear in mind is that sra changes with tracking force which may bring subtle improvements to the sound depending on your arm's effective mass that the recommended tacking force specs can't take into account...so it is worth experimenting. If 2.125 is the sweetspot in the technics arm then stick to it and enjoy!
I rather enjoy mine, did not like it much at first but after trying different cartridge alignments I found that it really cleaned up any flaws it had.
Well, don't keep us in suspense... LOL What table/arm are you using, and which alignment ended up being the best for it?
It's on a modified sansui sr222 with the s shaped tonearm. I honestly don't remember which method I used. I used the alignment calculator you can find online, typed in turntable measurements and printed a couple off.
Testing one of my newest acquisitions I put one an AT95e and it seems to pull surface noise like crazy. The highs are quite unrefined and the lows OK but a little muffed. AB's with my Nagoaka MP-50 .... its like night and day.
So anyway ... why does everyone including manufacturers use the AT95e? Is it just that its cheap and "passable"?
It's the price that everyone is tripping out over. I have one of these and an Ortofon Concorde Pro S. I'd say they're relatively comparable with respect to detail, the sound signature is different, but that's not important. The point I'm making is that, even though this cartridge is only comparable to a low to mid range level DJ cartridge costing $100, the low price of $45 will cause quite a stur.
The other selling point would be the ability to upgrade the stylus to achieve better results than those low to mid range dj carts.
i have gotten a tt (thorens 209) that came with an AT95e and the tt retails for $1500. waaay better than i expected. i am not so ready to attack the 95. also, i had an AT440ML that was wonderful, not bright as some here infer. perhaps it's sensitive to VTA?
YES, it is.
Far from inexpensive, but the Ortofon Concorde Pro S body can be upgraded to a very nice sounding cartridge with an OM 20, 30 or 40 stylus.
Yesterday I worked on my home made table that I call ARcom. It has an AR platter, sub-platter, bearing and pulley from an old AR-XA and an ADC ALT-1 tonearm. The motor is from Hurst (300 rpm), the motor housing and plinth are made from 5/4 x 6" composite decking material, and the hollow insides are stuffed with non-hardening modeling clay.
My friend's small electronics store had a Audio Technics AT92e so I bought it an put it on ARcom. I paid $30 for the cartridge (including sales tax). All I can say is wow.
Pretty fun.
Has anyone here tried upgrading to the AT95sa? I no longer have an AT95e but I've been considering getting another AT120eb or trying the AT95sa.
The 95SA is as good as the 95 gets with an off the shelf stylus. That is to say, quite good, but you've brought up an interesting comparison. Transplant a 120 stylus into a 95 plastic stylus carrier and the winner is a matter of opinion. Tough call.
Maybe the answer depends on your application - another table or another cart. You already have a 120 body and you can use any 100/120 series stylus with it. With the 95 you're limited to 3400 series bonded tips, but the body has slightly lower inductance which gives smooth response. I assume that's why Clearaudio chose the 95 generator for their MMs.
neo
I'm attracted to the low price point of the 95 for a good daily driver so I don't wear down my 120e or 150mlx stylus as quickly.
I've also been interested in the new 95ex which is paired with the new AT-LP5 TT. I haven't seen the cart for sale on its own but wonder how it differs from the basic 95.
The finer stylus would probably have less wear than the basic 4 X 7 stylus. :)
This is a fantastic cart, at a very reasonable price. I have two of them, one in my AT-120LP-USB, and the other in my vintage Pioneer PL-516. It sounds as though the OP is having other issues. Calling Audio Technica for some free tech support might make pretty good sense. The issue could be related to the cartridge, or not.
The best sounding at its price point it may well be. It was the first aftermarket stylus I tried though I wasn't overly impressed. For only a little more money I picked up a Denon DL110 which was an enormous step up of the AT95e and is very affordable itself. I can't understand why you'd ever go below the level of the DL110 at its price point. Its worth saving a little longer for and at that price point there are many other quality options too.
I figure the AT95e as a budget cart. I found even the AT3482P with universal adapter sounds better than it, and at a lower cost.
