Atlantean 210 Speakers (Atlantis Corp)
speakerjoe00
New here! Looking to replace two mid-range speakers in my Atlantean 210 Speaker Cabinets. Can anyone help send links or find two speakers that will work please?
5.5” diameter bolt hole
8 ohm
4.75” cabinet cutout hole
One of the speakers is really crackly and scratchy, and sounds blown out.
Let me know if you need any other info or photos. Thanks, Joe
First step is to swap mids and see if the sound moves to the other speaker. What you might have is a crossover that needs to be done.
Are you suggesting to move the mid-range in the right cabinet to the left cabinet? Then vice versa? The mid-range speakers are connected to the 2 woofers in each cabinet, by the way. Thanks!
Yes switch midranges between cabinets
I switched mid-range speakers to opposite cabinets and the left cabinet seems to be clear and crisp, whereas the right cabinet is scratchy, crackly & muffled (regardless of whichever mid-range is playing). What are your thoughts on that? Thank you!
When you push gently and evenly on the midrange's cone, does it feel scratchy / rubbing ?
If so, mayby the voice coil has heated up and swelled.
If so ( again ) , it is time to look for a replacement...and it does not look that easy.
These look like good speakers but, rare.
I wish you the best of chance !
The problem is there's no easy off the shelf replacement. The two options are 1) going to Parts Express website and get help. 2)You could have the driver repaired by Millersound. Don't know how much they charge.
Thank you for both of your responses and helpful thoughts. Do you think these speakers might work? I know it might be tough to not see it in person. I talked with the owner over at USSpeaker.com and this is what he suggested.
I’ve also considered rebuilding the current ones if I can’t find one that fits well.
Appreciate all of your responses.
Thanks, Joe
Thanks, Joe
Ciare HWG130-8
So does the scratchiness travel with the midranges, or is it in the right cabinet regardless of the midrange driver installed? Just clarifying.
I had the same confusion while reading the response.
To further clarify to OP: You might want to put a piece of blue tape on the basket of the offending midrange, then swap again. If the speaker with the taped midrange sounds bad after moving, that's the culprit. If the scratchy sound stays with the cabinet that doesn't have the taped midrange, it's the crossover.
I've had to do this before. I thought I remembered which driver/speaker combo was bad, but didn't. Now I mark the suspected driver with a sharpie or tape or something.
If the midrange driver is at fault, I highly recommend Millersound!
