Have you turned the speakers over? Some are predrilled for Risers. :tresbon:
There's only an inch difference in front to back so I just split it and centered it with a half inch in front and a half inch in back
Umm, No.If you mount the slant riser flush at the REAR you will point the speaker UP higher.
Umm, No.
No matter where the riser is attached, the speakers will still have the same upward angle...
Umm, No.
Did you pass? :scratch2:?? Not according to what I learned in geometry or physics in the past.
If the slant is on the floor I agree. I will have to look and see if the angle side is is screwed to the cabinet or rests on the floor. Like I said I did not purchase a riser for my HII. My riser for Cornwalls are Not angled.
EDIT I looked at the HII risers, the flush side IS mounted to the bottom the HII. You are correct sir.
iIrc, Flat risers were for Large Rooms & Slant for Small.
