ssouci
Well-Known Member
I'm intrigued with the idea of using in-line attenuators on the input terminals of my Fisher integrated tube amp (model X-202)
it seems that modern input sources are too "hot" (too high voltage) for older equipment like a tube amp, for example a CD player, DAC box, etc... and that can overload the preamp circuitry
I'm hoping that by using attenuators, it will present the circuitry with a level more in keeping with what it was designed for, hopefully resulting in general sonic benefits, plus making the volume control sensitivity more usable (ie., increase the range of adjustment before the sound becomes too loud)
however, my research into attentuators shows a real mixed bag of results: some posters claiming great results and no degradation of sound with lots of benefits (better overall sound, less harshness with CDs, better volume control modulation), while others say it killed their high frequencies and sparkle, and to definitely avoid using them... very conflicting views EG: https://hifiwigwam.com/forum/topic/120698-rca-attenuators-influence-on-sound-quality/page/3/
I can buy a pair of in-line attenuators with RCA connections for approx. $30-60, which is not outrageous considering all the (potential) benefits... EG: http://www.hlabs.com/products/attenuators/
NOTE: I run an Oppo BDP-83SE disc player with output voltage of 2.2V(?), connected via the Aux input
QUESTIONS:
Q1. what level of attenuation should I use with an X-202?
Q2. will using an attenuator degrade the sound of my amp... how and by how much?
Q3. if it will degrade, would using the lowest worthwhile level of attenuation help?
Q4. what brand of attentuator can users recommended? eg. Goldenjack, Harrison, Rothwell
(I'm located in Canada, so looking for most cost-effective brand shipped there)
any advice hugely appreciated!
QUESTIONS:
