Sriskie
Well-Known Member
I'm replacing the 2sc1313 with KSA1845 as preventative maintenance during a full rebuild.
TR-05,06 on the F-2570 equalizer circuit board have a 1k resistor connected to the base of the 2sc1313 transistors. I want to replace them with KSA1845FTACT but I'm getting different readings when tested with my Peak Atlas DCA55.
The 2sc1313 are reading "LED or DIODE JUNCTION".
The KSC1845 are reading "NPN DIGITAL TRANSISTOR".
What does it all mean? Does the lower voltage of the tester show something that's irrelevant when it's in circuit at working voltage, or would this substitution make an unwanted change in the circuit?
