AU 417 help
MarkoinMn
Question for you all. I lost left output for phono 1 and 2 last night on my AU-417. It's not the tt as that's working fine hooked up to my Luxman now. AUX and Tuner left channels work fine. Happened at loudish volume after needle skipped and it went into protection mode. From what I've read it seems perhaps a fuse transistor blew. Any thoughts or experience with this here? Thanks.
There are four 82 ohm fusible resistors in the phono stage, two in each channel. Quite possible that one or more has gone rogue.
