Oh, jeez hopefully everything will be okay. Everything works as it should on its own and I’ve switched the two interconnects.Not good to double post.
Does the 555 work normally if you hook up speakers? Have you tried different cables? A different preamp with the tube amp?
Do some basic troubleshooting.
... I’m trying to use my au 555a as a pre amp for an mt 34 mk 2 tube amp but I’m not getting full power to my left speaker.
Turntable into phono1 and then pre out on 555 to aux on tube.At this point the issue would be with the Power amp not the Sansui as all you're using that for is for Pre-Amp duty.
How are you connecting the Sansui to the MT-34
For those following along the tube amp in question is a Boyuurange MT-34 MKII integrated amp
..How are you connecting the Sansui to the MT-34
..pre out on 555 to aux on tube.
Jesus, okay. I was trying to use the sansui for the tone controls. Try and tone down the shouty ness of the mt34. I don’t know how to patch it back to the sansui.It should work. The Sansui does have pre out and main in jacks. The pins just need to be pulled and patch cords used from the Sansui pre outs to the MT-34 AUX inputs.
Only thing here is that if there are no patch cords Y'd back to the Sansui, only the MT-34 will produce sound.
Tyguy1, not sure if the MT-34 has tone controls, but since it is an integrated amplifier, you will have two volume controls to contend with.
Most people having more than one amp like to run 4 speakers instead of 2.
You would have 2 speakers connected to the Sansui, and 2 speakers connected to the MT-34. The Sansui would be the main control unit with its own pair of speakers, and the Sansui will also control the MT-34 with its own pair of speakers.
