Greetings to you all.
I own a sansui au-5900 that was working great.
But, some problems started with the right channel of phono-1 (no output on speakers, phones and pre-out).
Then the problem expanded in no output to the speakers for both channels and for any input.
The thing is that using the pre-out output and another amp, works fine except the phono-1 that still has no right output. Also. if I turn the volume full up, i can hear a little distorted sound of the input, but like I am on wrong input channel.
I have already check the four fuses, and seems ok.
Has anyone any idea what to check or what is going on?
Thanks in advance for any suggestion...
