AU-666 +20V DC offset on each channel?
Hi all,
Problem is solved, it was as AnalogueBen said a problem with wrong input transistors.
New ones were sourced and the AU-666 is up and running, sounding even better than its little brother. Time to replace the 555 :D
Only thing left to solve is Tape in, which seems to intermediately ground out right channel? Which will be solved another day
Thanks for the help everyone
Great to hear!
That ground issue is can be probably traced back to an exposed wire coming into contact with the chassis, switch contacts or something of that nature.
Also, highly recommended is to remove the subsonic filter, same procedure as the AU999, a search will bring up the info. Enjoy
