Hey all, I am trying to confirm Main Cap specs. From my service manual, original Main Caps are 15,000uF, 63V, EC. I have not torn the amp down yet. I am in "research & information gathering mode." In the LeeStereo AU-717 restoration thread Ben says "For future reference, a good "drop-in" replacement currently being manufactured is the Nichicon KG (Gold Tune) 15,000µF/63V capacitor, which uses solder lugs and is of the same 40mm diameter as the originals. (LeeStereo)." I have downloaded the datasheet (attached) and found there are Type I, II (both Gold Tune), and Type III (Super Through). During my research, I seem to remember reading in a thread the the original output caps were 85mm in length, but of course I didn't document it. In the datasheet the only Gold Tune in 15000uF/63v is a Type I, which is 40mm x 68mm (pn LKG1J153MKNF). The Type II Gold Tune is 40 × 100 (pn LKG1H153MKN). From what I have read all recommendations (including the datasheet) are for the Type II, but I don't know that 100mm height will fit. I understand there are compatible Kemets. I just wanted to follow up on Ben's recommendation.
Thank you in advance, K.
when I reconditioned my own AU-717, (was it as long ago as that!?) I used 15,000µF, 63V Nichicon KG Gold - which are 40mm x 100mm - identical to the originals size-wise.
