MIJ_Pioneer
I fell in love with the look of the AU-717 and was surprised by its lower cost and availability. Dual mono integrated amp is new to me, I have mainly used receivers only. The look of the 717 with the top off I thought would really be a nice piece to show some of the workmanship. I had been looking for one for a few weeks and finally found one in the area. A nice guy had it for sale, he said it was his good friend's who had bought it new and barely used it. From the looks of it I would agree. It's mint!
The 717 for me has been the hardest piece of equipment to service (I've recapped sx-1280, 1250, 650s, 7070). It just took a long time, piece by piece. This one has every single transistor replaced other than the outputs. Lots of room for error (and there was some). The power board was difficult, hard to get out, hard to troubleshoot, packed tight, lots of glue, and has those pins that Sansui used to run through the solder pads. I spent about 14 hours on the power board alone! The whole time I couldn't imagine being a tech doing this for money and/or offering this full recap/diodes/transistors/lube/clean etc service. The cost of the unit itself would way outweigh the time/cost that would go into. I will say - when I first got it I knew it had potential but it was tired. Sounded lifeless, bass was boomy/muddy. Almost on or off. Now that it is serviced it sounds completely different. I noticed the biggest change when the powerboard was done.
Overall it is a fantastic piece, one the best I have ever heard. I am very impressed what kind of power it puts out for just two output transistors per side. I A/B'ed it with a recapped 1280 and I don't know how Sansui does it but the bass is just out of this world. The 1280 (and 1250) have a phenomenon where they get real loud but from what I have noticed is bass really taxes them (at near max volume). If you're cranking and a big bass note shows up the big Pioneer might clip into protection. The 717 really was giving bass that the 1280 wouldnt do. One of the listeners said a few times "the 1280 would be dropping right now". Obviously didn't get as loud but it certainly held its own.
Thank you to LeeStereo and Super Noob for their work on the 717 and documentation. 99.9% of this BOM is Super Noob's which he created for LeeStereo's guide.
SuperNoob: https://audiokarma.org/forums/index.php?threads/project-sansui-au-717-bks.896463/
LeeStereo: https://audiokarma.org/forums/index...estoration-upgrade-of-a-sansui-au-717.641945/
Tone Board:
Filter Caps Bottom:
Power Board:
Filter: 4x ALT22A153DE063
4x: ECW-FE2W225J
F-2721 (Amp Driver Circuit Board) Right / Left Total (2) Double Below
D01-D04 – 1S2473 / Now 1N4148
ZD01-ZD02 – EQB01-22, 22v 1-Watt Zener Diode / Now 22v 1.3-Watt (BZX85B22-TR)
C02; C04 – Original 33uF 25v / Now 100uF 35v (Nichicon UPW1V101MPD)
C12 – Original 1uF 50v / Now 1uF 63v (WIMA MKS2C041001F00JA00)
C11 ; C14 – Original 470uF 63v / Now 1000uF 63v (Nichicon UPW1J102MHD)
R15 – Original 10k Ohm ¼-Watt / Now 10k ½-Watt MBB02070C1002FC1 (1% Metal Film)
R16 – Original 27K Ohm 1/4 -Watt Carbon Resistor / Now 27K Ohm 1/4-Watt Metal Film (KOA Speer MF1/4DC2702F)
R23 ; R25 – Original 150 Ohm Fusistor / Now 150 Ohm 1/4-Watt Metal Film (1% KOA Speer MF1/4DCT52A1500F)
TR01-TR02 – Original 2SC1400 ECB / Now KSC1845F (HFE Matched)
TR03-TR04 – Original 2SA750 (PNP) ECB / Now KSA992FB
TR05 ; TR11 – Original 2SA899 / Now KSA1220AYS
TR06; TR09 – Original 2SC945 / Now KSC945CY
TR07-TR08 – Original 2SC1904 / Now KSC2690AYS
TR12 – Original 2SD382 / Now MJE15032G
TR13 – Original 2SB537 / Now MJE15033G
VR1 – Original 100 Ohm Trim Resistor / Now 100 Ohm Single Turn Sealed 3/8” (Bourns 3386H-1-101LF)
VR2 – Original 2.2K Ohm Trim Resistor / Now 2.2K Ohm Single Turn Sealed 3/8” (Bourns 3386H-1-222LF)
VR3 – Original 1K Ohm Trim Resistor / Now 1K Ohm Single Turn Sealed 3/8” (Bourns 3386X-1-102LF)
4x Output transistor Micas 534-4636
F-2263 – Power Supply
C05-C08 – Original 220uF 63v / Now 820uF 63v (Nichicon UPW1J821MHD)
C09, C10, C11, C12 – Original 100uf 63v / Now 330uf 63v (Nichicon UPW1J331MHD)
C17-C18 – Original 470uF 16v / Now 470uf 25v (Nichicon UPW1E471MPD)
C19-C22 – Original .47uf 50v (LL) / Now .47uf 100v (WIMA MKS2D034701E00KSSD)
C23-C26 – Original 100uF/35v / Now 220uF 50v (Nichicon UPW1H221MPD)
C701- C704 – Original 15000uf 63v / Now 15000uF 63v KEMIT ALT22A153DE063 (85C 26k Hour)
C707- C710 – Bypass Caps Polyester Film 2.2uf 100v / New 2.2 uF 450v Polypropylene Film (Panasonic ECW-FE2W225J)
R7, R8, R9, R10, R11, R12, R13, R14 – Original 10k Ohm ¼-Watt / Now 10k ½-Watt 594-MBB02070C1002FC1 (1% Metal Film)
R33-R34 – Original 22k ¼-Watt / Now 22K ½ Watt 594-MBB02070C2202FCT (1% Metal Film)
D05-D12 – 10D2 1-Amp Diode / Now MUR220RLG, 2A / 200V Ultrafast Diode
D13-D18 – 1S2473D; 1S1588 Diode / Now 1N4148
D601 – D602, 10D2, 1-Amp Diode / Now MUR220RLG, 2A / 200V Ultrafast Diode
D603 – 1S2473D; 1S1588 Diode / Now 1N4148
D604 – VD1212 Varistor / Now Double (Series) 1N4148 Diodes
D605-D607 – 1S2473D Diode / Now 1N4148
D608 - Diode, 1A/100v, 10D1 (1S2226)): /1N4004T 1A/400V
D609-610 - VD1212 Varistor / Now Double (Series) 1N4148 Diodes
ZD01-ZD02 – RD13E (B) 13 V, ½ Watt, Zener / 13W, ½-Watt, Zener, 1N5243B
ZD601 – EQA01-06R, 5.6V, ½ Watt, Zener / 5.6W, ½-Watt, Zener, 1N5232B
ZD602 – RD13E Zener 6.2V, ½ Watt, Zener / 6.2W, ½-Watt, Zener, 1N5234C
TR01-TR2 – 2SD356 / Now MJE15032G
TR03-TR04 – 2SB526 / Now MJE15033G
TR05-TR06; TR09-10 – 2SC1708 / Now KSC1845FB
TR07-TR08; TR11-12 – 2SA847 / Now KSA992FB
TR601-TR603; TR605-607 – 2SC945 / Now KSC945CY
TR604 – 2SA733 / Now KSA733CY
C601 – Original 47uF 50v / Now 100uf 63uF (Nichicon UPW1J101MPD)
C604 – Original 470µF 10V / Now 470uF 25v (Nichicon UPW1E471MPD)
C605 – Original 33uF 50v / Now 47uF 63v (Nichicon 647-UPW1J470MPD)
C606-C607 – Original 4.7µF 50V / Now 4.7uF 63v (Nichicon 647-UPW1J4R7MDD)
C29-C30 – Original 220µF 6.3V (bipolar) / Now 220uf 25v (Nichicon 647-UES1E221MHM)
Relay = Omron MY2-02-DC24
F-2720 –Tone Control
C05-C06 - Original 0.33uF Polyester Film / Now .33uF 450v Polypropylene Film Panasonic ECW-FE2W334J (5%)
C07-C08 – Listed 10pF Found 22pF Ceramic / Now 22pF 100v (C0G) RDE5C2A220J0M1H3A (5%)
C15-C16 – Original 10uF 16v / 10uF 35v (Nichicon 647-UKL1V100KDD1TA)
C21-C22 – Original 10uF 16v (signal) / 10uF /35v (Nichicon 647-UKL1V100KDD1TA) LeeStereo- Ben Prefers UES Here
C23-C24 – Original Listed 10pF Found 22pF / Now 22pf 100v (C0G) 5% RDE5C2A220J0M1H3A
C25-C26 – Original 0.47uF Polyester Film / Now to 0.47uF 250v Polypropylene Film WIMA MKP4F034704D00JB (5%)
C27+C29; C28+C30 – Original 100uF 6.3v Polar In Series for Bi-Polar Configuration / Now Single 47uf 16v Nichicon UES1C470MPM (Bi-Polar)
C31 ; C32 – Original .1 uF Film (bypass) / Removed
C33/C35; C34/36 – Originally 4.7uF 50v (LL) in Series for Bi-Polar / Now Single 2.2 uF 450v Polypropylene Film Panasonic ECW-FE2W225J (5%)
C39-C42 – Original 47uF 50v / Now 220uF 50v (Nichicon UPW1H221MPD)
C45-C46 – Original 10uF 25v (LL) / 10uF /35v (Nichicon 647-UKL1V100KDD1TA)
D01-D02 – Original VD1212 Varistor / Now Double (Series) 1N4148 Diodes
R37-R40 – Original 82ohm ¼ Watt Fusitor / Now 82ohm ¼ Watt Metal Film KOA = MF1/4DCT52R82R0F (1%)
TR01-TR06 – Original 2SA726 (PNP) ECB / Now 512-KSA992FBU (HFE Match) TR1/TR5 ; TR2/TR6
TR09-TR12 – Original 2SC1400 ECB / Now 512-KSC1845FTA
TR07-TR8, TR13-TR14 – Original 2SA750 (PNP) ECB / Now KSA992FB
F-2670 – Pre-Amp Switch Board
C01 - C04 – Originally 10uf 25v (polar caps in series for bipolar) / New 2.2 uF 450v Polypropylene Film (Panasonic ECW-FE2W225J)
ECW-FE2W225J | 2
F-2723 – Tone Control Board
C01-C02 – Original 1uF Polyester Film / Now 1uF 450v Polypropylene Film TDK B32672Z4105J00 (5%)
C03-C04 – Original 100pF Ceramic / Now 100 pF 100v Polypropylene Film WIMA FKP2D001001D00JO00 (5%)
C05-C06 – Original 220uF 6.3v / Now 470uf 25v Nichicon 647-UES1E471MHM (Leestero prefers Bi-Polar Here)
C19-C20 – Original 10uF 16v / Now 10uF 35v (Nichicon UKT1V100MDD)
C27+C29 ; C28+C30 – Original 10uF/25V (LL) in Series / Now 4.7uf 63v Stack Polyester Film WIMA MKS2C044701M00JO00 (5%)
C31-C34 – Original 10uf 50v / Now 47uf 63v (Nichicon UPW1J470MPD)
D01-D04 – Original VD1212 Varistor / Now Double (Series) 1N4148 Diodes
R47-R50 – Original 82ohm ¼ Watt Fusitor / Now 82ohm ¼ Watt Metal Film KOA = MF1/4DCT52R82R0F (1%)
TR01-TR02, TR05-TR06 – Original 2SA906 (PNP) BCE / Now KSA992FB (HFE Match) TR1/TR5; TR2/TR6
TR03-TR04 – Original 2SA726 (PNP) ECB / Now KSA992FB
TR09-TR10, TR15, TR16 – Original 2SA750 (PNP) ECB / Now KSA992FB
TR07-TR8, TR11-TR14 – Original 2SC1400 ECB / Now KSC1845F
BOM:
512-1N4148| 35
BZX85B22-TR | 4
UPW1V101MPD | 4
MKS2C041001F00JA00 | 2
UPW1J102MHD | 4
594-MBB02070C1002FC1 | 11
MF1/4DC2702F | 2
MF1/4DCT52A1500F | 4
512-KSC1845FTA | 19
512-KSA992FBU | 100
512-KSA1220AYS | 4
512-KSC945CYTA | 11
512-KSC2690AYS | 4
MJE15033G | 4
3386H-1-101LF | 2
3386H-1-222LF | 2
3386X-1-102LF | 2
534-4636 | 8
UPW1J821MHD | 4
UPW1J331MHD | 4
UPW1E471MPD | 3
MKS2D034701E00KSSD | 4
UPW1H221MPD | 8
667-ECW-FE2W225J | 12
594-MBB02070C2202FCT | 2
863-MUR220RLG | 10
621-1N4004 | 2
512-1N5243B | 3
512-1N5232B | 2
512-1N5234C | 2
512-KSA733CYTA | 1
UPW1J101MPD | 1
647-UPW1J470MPD | 5
647-UPW1J4R7MDD | 2
647-UES1E221MHM | 2
MY2-02-DC24 | 1
ECW-FE2W334J | 2
RDE5C2A220J0M1H3A | 4
UKL1V100KDDANA | 6
MKP4F034704D00JB | 2
UES1C470MPM | 4
MF1/4DCT52R82R0F | 8
B32672Z4105J000 | 2
FKP2D001001D00JO00 | 2
647-UES1E471MHM | 2
UKT1V100MDD | 2
MKS2C044701M00JO00 | 2
MJE15032G | 4
Tone Board:
Filter Caps Bottom:
Power Board:
4x: ECW-FE2W225J
ECW-FE2W225J | 2
BOM:
512-1N4148| 35
BZX85B22-TR | 4
UPW1V101MPD | 4
UPW1J102MHD | 4
MF1/4DC2702F | 2
512-KSC1845FTA | 19
512-KSA992FBU | 100
512-KSA1220AYS | 4
512-KSC945CYTA | 11
512-KSC2690AYS | 4
MJE15033G | 4
3386H-1-101LF | 2
3386H-1-222LF | 2
3386X-1-102LF | 2
534-4636 | 8
UPW1J821MHD | 4
UPW1J331MHD | 4
UPW1E471MPD | 3
UPW1H221MPD | 8
863-MUR220RLG | 10
621-1N4004 | 2
512-1N5243B | 3
512-1N5232B | 2
512-1N5234C | 2
512-KSA733CYTA | 1
UPW1J101MPD | 1
647-UPW1J470MPD | 5
647-UPW1J4R7MDD | 2
647-UES1E221MHM | 2
MY2-02-DC24 | 1
ECW-FE2W334J | 2
UKL1V100KDDANA | 6
UES1C470MPM | 4
B32672Z4105J000 | 2
647-UES1E471MHM | 2
UKT1V100MDD | 2
MJE15032G | 4
