Every now and again we have someone asking questions about weird regulated PSU voltages for an AU-717 during restoration i.e. with the Driver Modules removed or other boards unplugged. The reason for this is that with the Driver Modules installed they complete a ground path for the whole amplifier including crucially the regulated PSU. If the ground path is interrupted by removing connectors or whole boards the regulated PSU's show weird voltages - because they have lost their ground reference.
If you have a partially dismantled AU-717 and you want to restore the regulated PSU functionality to test that they work after rebuild or for testing other board restoration work, you can do the following.
Assume you have the Driver Modules removed and all the connectors in the below picture are hanging loose. If you connect the black ground connections to the respective ground returns as indicated below this will make the regulated PSU output correct if there are no other faults.
As a test of this procedure I simply stripped the ends of two pieces of insulated wire (of similar thickness to the black and white cables seen below), and folded the stripped ends over to cover the insulation. This makes the stripped cables the right size to (temporarily) fit into the ground wire holes in the female connectors at the top (power amp input connectors), and also into the grey push on connectors with white wire and black wire. (remember these are all hanging loose and disconnected). Ensure the stripped and folded wires can't short on anything!
The regulated PSU voltages should then be correct at ~ +/-33V for each regulator.
NB for safety do not make these connections with the amplifier powered on, and you can do this on DBT, and it should work just as well for this brief test.
The above is a picture of an AU-717 owned by another AK member ( @sansui au719 ) that I am reconditioning for him.
Any questions, or something not clear just ask.
I am not in the habit of replacing current amplifying transistors outright, but doing so on the driver boards in this unit made them way more stable than before. Maybe my F-2663 needs the same?
