AU-717 Total Rebuild/Rack Refurbished
jfouch59
I received my fully restored AU-717 from Leo at Precision Audio Restorations on Saturday. I’m the original owner of this marvelous amp. The volume control was stiff and the left channel was silent. I sent it off to Leo based on recommendations from this site. Leo did an absolutely excellent job repairing and re-capping this amp. It was previously repaired many years ago when one of the output transistors was replaced with a non-Sanken unit. He replaced that with an original Sanken transistor and backed out some driver transistor mods and other non-standard fixes that were done at that time. There were a few other minor issues that Leo also addressed, polished the front panel and touched up a minor nick on one corner. He kept me informed every few days on the repair status and even sent me a brief video of the amp being tested on the bench. I cannot express how pleased I am with the quality and timeliness of his work.
While the amp was out, I took the time to refurbish the rack and do some fixes on my other components. The rack itself needed some attention. The top deck and lower base were made of ½ inch or ¾ inch particle board or some type of pressed wood fiber panel covered in a vinyl veneer. Over the years they both warped a bit and the entire rack was tilting towards the back. I replaced both with 11 ply ¾ inch plywood and braced the base with additional cross supports. The top deck now sits level which is handy for the turntable ;) I polished a fingerprint off the Nikko tuner pointer that was probably put there when it was assembled. It drove me nuts! I replaced the burned out light bulb on the SE-7 EQ power button with an LED. The sliders were cleaned with Deoxit D5. The walnut wood panels on the SAE INRS got several coats of linseed oil. I sourced a cheap Sony dual tape deck for now. Maybe I’ll try an upgrade there later. I also added a combo power meter/power outlet to help with providing power to everything. Adds a little light show to the rack.
The restored system sounds and performs great. I’ve been listening to some old tapes I dubbed back in the 70s and 80s. Listened to some albums I have not heard in a long time, some really good stuff.
Anyway, I got long with this post but wanted to share. If anybody is looking for a good restore technician, this is my recommendation. Precision Audio Restorations did a fabulous job for me.
That's fantastic, great to hear!
You came to the right place (AK) to inquire about having your Sansui properly repaired/ restored. I didn't hesitate recommending Leo because I knew the job would be top-notch, he has worked on some of my stuff and definitely has the proper equipment and skills to do it right. I didn't get a chance to stop by his shop and listen to your specific unit post-restoration but I have heard other 717 units that he's restored and the before and after sound improvement is undeniable.
It's nice to see a new member come here and have a great experience right off the bat. Welcome again to AK and specifically the Sansui sub-forum. You will find that there are many qualified and helpful individuals here.
BTW, if anyone is curious Leo is @Aud10file. He recently started putting together a website for his restoration services precisionaudiorestorations1.com . I'm looking forward to seeing his thread here on AK documenting your restoration. :lurk:
Enjoy your newly restored amp.
@jfouch59 : Thank you for your kind words. I’m glad to have been a part of your music journey. BTW: The rack looks really good. Enjoy!
@Vintagear : Ditto on “you will find many qualified and helpful individuals here”. It is rare to find forums such as the ones on AK.
I’ll try to start a thread to cover the more interesting items encountered in this restoration, hopefully tonight.
I have a Sansui AU-919 that needs some work. The power switch won't turn off. It stays on in both positions.
What did it cost to do the repairs? I might want a full restoration as long as I don't have to pay over $400.
Good job on the rack restoration!
I wanted to mention that it looks like the AU-717 might have an airflow issue with the tuner and power meter being so close above and below. I know it probably wouldn’t look as nice but I’d suggest shifting everything so that the amp has some space above and below. The amp could go up top with some open space above (you probably interact with it the most anyway, so it could be good ergonomically as well), then some space below, then the rest of the stack. I’d hate to see the rebuilt amp have a shortened life because of heat issues!
Samson. The total rebuild came in a bit over $600 but for the quality of the work that was done, this is about the market rate for these vintage units. You may find more reasonable rates but good work will not be cheap. For your budget, you can probably get the power switch and other minor upgrades but I went for the whole smack.
CRV00 makes a good observation. I have not noticed any heat buildup in the past. The little power meter/outlet manager below the 717 is only about 4 inches deep. Almost all of the bottom of the 717 is open below. There is quite a bit of space along the sides of these units in the rack so I think that helps. I work in a large IT department and I've thought about re-purposing a retired 4 post server rack. Cutting one down to a reasonable height and rendering a more post-modern, open air industrial appearance rather than a period correct 70's vinyl laminate look. I might also put a small fan back there. Lot's of those lying around.
I think I’ve read that the hole spacing on the Sansui rack and handles doesn’t conform to standard equipment racks so you might need to make modifications to a server rack. I could be totally wrong though!
