Au-919 questions
ghamilton
Does anyone know if there are any MOSFETS somewhere in the 919?
In the article about "HOW SANSUI AMPLIFIERS ARE DESIGNED" in part 2 the "MOSFET" is talked about. It says "Making use of these (MOSFET) transistors, the two-pole filter and the DD/DC driver stage,.......
Now I know that the outputs are NOT MOSFETS. So, there must be some in there somewhere. Right?
Tr 29-30-31-32 on the driver board are in question for me. It says "M.L.K." at the end of the transistor number. Could the "M" stand for "MOSFET"?
Thanks guys!
M, L, & K are hFE gain ranks for those transistors in question. There are no metal-oxide semiconductor FETs in the 919 but there are JFETs.
Some of you guys have read "HOW SANSUI AMPLIFIERS ARE DESIGNED".
I sent copies by e-mail to those who ask for it. What does it mean when it talked about the MOSFET?
having read this again, MOSFET's exhibit similar characteristics to valves, and it was assumed as they have a high input impedance, they would be easier to drive. However when they tested it, due to high input capacitance, the driver circuit (DD/DC) still need to be built complex and robust to overcome the effects of high capacitance to achieve the desired slew rate. It was not as simple as initially thought.
Amps based on MOSFET's I believe came after AU-919 lot later in the 80s.
Fwitw
I remember studying FETs (Field Effect Transistors) at night school in the late 60s or maybe early 70s. Their principle feature was very high input impedance as I recall (to which Mano refers above). I don't recall if these were different to Metal Oxide Semiconductor FETs or simply a name change in the meanwhile..
Not a name change - they are significantly different.
This will help: http://www.ustudy.in/node/7694
I suppose they jumped the gun in this article before they tested it.
Thanks!:)
IGFETs were Insulated Gate FET's I think - I don't remember what their claim to fame was though ;)
IGBT, Insulated Gate Bipolar Transistor, noting the likes of the Toshiba pairs, GT20J101/GT20J201
Now obsolete!!
