Segasonic91
Continuing on from my thread about channels dropping out, I have started to recap as I was getting LOUD pops and clicks and it was then going into protection. As I was told it is resistors that cause this, I decided to start work with what I have on hand (still waiting for some backordered caps).
I replaced all caps on boards F-2567 and F-2568, as well as all A726 and A1313 transistors on F-2568.
After testing, I was not getting the relay kicking in. I am 100% positive all caps are in the correct polarities, I will not make THAT mistake again! So I will have to double check the 6 transistors I installed. Again, I am certain they are in correctly. I installed going off the readings of the transistors in the tester, but I will double check tomorrow.
The only caps I was not sure about where the 2 100uf, 80v caps on the underside of F-2567. I forgot to check before I took the old ones out. I lined up the old caps and it seemed like negative was on the outside, and positive were conected to the centre. Is that correct?
On another not, I discovered that F-2568 and the phono board (F-2570) were recapped. Terribly, I might add!! Every capacitor was the wrong uf value! What ever moron did the work, they linked two 470uf/160 caps together in place of the 220uf/10v bi-polar cap!!! No WONDER this thing has problems! All of those shitty, cheap caps are out and replaced with CORRECT value Panasonic FC caps. I guess this was yet another lie by the seller, I was told it had never been re-capped.
