SuperTech234
To anyone who may have info on this model. I recently recapped and fully restored this AU-D7.
It had 2 blown output transistors,2 drivers,the bias transistor,the bias resistor, the bias and dc offset pots and a couple small transistors on the driver pc that were bad and a few .5 watt resistors as well.
After repair and restore I was able to adjust the dc offset and bias it out good.
After running it a while you turn up the volume and even though its not drawing excesive current and running clean sound it blows up the same channel again. I have repaired it 2 times and had the same result.
Is it possible that this is one of the sansui models that requires exact japanese replacement parts ?.
Thanks in advance.
Thanks in advance.
