I got another dirty one. This is a Japanese domestic 100V unit so I will be using a step down converter. I'm hoping this will be pretty close to the AU-X1 because I can't locate a service manual for the AU-X11.
When I got this thing I was a little bummed about the condition and was wondering if I bit off more than I can chew. The unit was shipped in a very sturdy box but wasn't protected with plastic. The cardboard rubbed off the screening on the face where the model number is and a couple of spots around the controls. The back panel is bent causing the cover to not seat correctly and the wood corners are crushed. If I can get this thing back to sounding great I'll replace the sides.
Inside its not too bad, the transformer has some light surface rust and its a little dusty, not too bad. I powered it up with the converter and dim bulb tester and all I get is the blinking protection light and a bright dim bulb tester. It looks like its not functional. I'll start working on this one board at a time replacing the have to parts and testing the questionable ones. I'm hoping that the factory outputs and FETs are ok. We'll see.
Here are some pics.
Step down transformer
dim bulb tester
I'll start working on this once I finish the AU-717 and QRX that I'm working on.
Here are some pics.
dim bulb tester
