x37tuna
good monrin everyone........well just to start off..ive been e sprayed.....picked this au717 up on the bay..if anyone saw it it was the one the right channel doesnt come on untill the unit warms up for about ten minutes,,,,well.....its been on for about three hours now cant get a sound out of it...i did do some pokin round..very clean unit...well takin care of...everything looks in order..i did switch the driverboard singles...f 2721,f2722...agian only only the left single comes through.. so i believe that the driver boards are in good shape..just so its clear..i did run the tuner through the aux..then the tuner.tape inputs with no change...i went a little furthter and ran the tuner through the pre out, power amp in section..of course the switch was dirty (cleaned it) and got good sound out of both channels..but of course no pre amp adjustments...so im guessin that the problem is in the pre amp section.. this is a nice unit.just as good if not better then the one im running now...except the one im running now works...lol....even so...mybe someone out there can give a rookie some sdvice on takin the next step in tryin to figure this thing out...i have posted on here before and received a lot of helpfull information...this is a great site...oh yeah i did adjust the offset and bias witch wernt that bad really and both boards hold the adjustment pretty good im around .3 mv on both sides, 0 to .1 on the bias.. that made me feel good.........................
