The actual schematic seems to be well protected by AI. I wonder if someone went through the effort of drawing one? Is there a known solution to lower filament voltage? Mine runs tubes at 6.67VDC. Voltage is regulated but why were they designed to run tubes so hot?
Also, another issue.
This unit has been recapped in 2020 but wasn't really used so doesn't have many hours on it.
Filament rectifier diodes were replaced with a tabletop bridge with the heat sink on its back.
Tubes are 6922EH from McShane. Those were briefly used in another preamp and have several hours more on them than this preamp itself after the recap but I'd still consider them near new.
The frequency response drops fairly quickly above 5KHz which is also supported by the rolled-off leading edge in the square wave display. If I have to guess, those tubes have less than 20 hours on them, and half of that was in the VTA PH-16. If this Modulus ate them this quickly, something must be done before I start looking for new tubes for it. Any suggestions are appreciated.
