Glad to see you're still around
@arts, I hope you are doing okay.
Thank you Sir,much appreciated! I'm still not up to my "usual self ",but I'm feeling great and I'm back to work. As I've mentioned before,it's nice to still be on the sunny side of the dirt
@Dazaa
I'm in the process of pricing out a set of (16) kt120 power tubes for my ARC monoblocks and looking at like $700+usd for a set that aren't even matched. This doesn't include the other necessary matched (8) 61np for an additional $100usd.
IIRC, aren't you running a pair of VM220s? Hee hee,that's another tube pig; and I thought my VS110 was bad
Do you know if the D250 has any known weak points or service bulletins that need addressing?
Other than the costs associated with maintaining or repairing one of these,I do not recall any design-related weak points other than the fans getting noisy (usually dry bushings,easily dealt with) and the internal filth that comes with a fan-cooled amplifier.
As for service bulletins,I will have to dig into my files and see if I have anything on that.
But by this time (big,expensive "but" here),it probably has a multitude of weak points.All electrolytics and any carbon composition resistors will be suspect. Also,verify that all of the semiconductors are the correct types as specified in the manual. You cannot just bung in whatever seems close,but many times this will have happened. Look for any evidence of previous repairs and if any are found, validate that correct parts and values were used.
And just to reiterate: PLEASE heed my electric chair warning. Also,if a blow-out resistor or semiconductor fails,it will generally do the electronic equivalent of a grenade,so if you run it without covers while working on it, wear safety glasses.
I don't usually do the "nanny" thing Dazaa,but trust me mate,this one is a seriously nasty piece of work.
Cheers,
Art
