Good, that ratio is easily above the 10:1 rule, and should be fine, but 1100-ohm output impedance is moderately high, compared to when using a solid state preamps into the solid state amp. Maybe try a short interconnect with a low-capacitance cable, and see if that effects the sound at all. Just suggesting these random things to scratch off the list and easy to check and eliminate; and help narrow down what you could be hearing; before feeling like you have to go back inside the chassis's.SP-10 out 1100 ohms, amp in 47K
