When I asked about this adjustment procedure, in my mind was Brian Clark´s article about SP6 mods in Audio Amateur in early 80´s. Clark did mention that unregulated heater supplies in SP6 caused trouble in intermediate stages with 2K21 cathode resistors. Cathode and anode resistors had remained same since SP3A.
I was not aware of this article and a quick search yielded nothing on it.
[/QUOTE]SP6A revision added regulated heater supply for gain stages, but cathode followers were powered with unregulated DC. Intermediate stage 2K21 cathode resistors were replaced with 1K21 or 1K5 to improve circuit´s stability against changes in heater supply voltage at expense of poorer large signal linearity. This seems a bit odd as heater string was now regulated, but maybe filament tolerances of tubes were not as good as in earlier years.[/QUOTE]
My SP6 came with EI 12ax7 and 6922 tubes. As far as I could tell were from the factory.
[/QUOTE]As the heaters of gain stages are series connected to 24V supply, even with regulated 24V, heater power is not necessarily equal for each triode section, due to the manufacturing tolerances. Therefore it is most likely that different combinations of 12AX7 tubes can produce different combinations of cathode emissions and therefore quite different sound qualities.[/QUOTE]
As I mentioned above if you refer to the schematic only one triode section per tube is used. The other half is a place holder. When I get the opportunity I would like to trace the signals out to see if each channel is mirrored.
[/QUOTE] I suppose that this must have been the main reason for trimmer adjustable cathode resistance of intermediate stage 12AX7´s in 6C. However in 6E fixed 1K5 cathode resistors were consider to be enough and most likely in 6C1, if trimmers on 6C1 board are not operative. Early SP8 used 1K5 intermediate stage cathode resistors, then switched to 1K values and later back to 1K5. [/QUOTE]
It is entirely possible that there was a running change in the topography from the factory, ARC was and still is famous for this. I do not have my SP6 here to look at and when I called to get an owners manual I was asked to give the serial number. If nothing else ARC keeps meticulous records.
[/QUOTE]This topic is interesting... I hope that there is someone around here with more information.
Best Regards
Kimmo[/QUOTE]
Same here...if you find the article please get it to me. If your confident in your assumptions and handy with a meter it shouldn't be difficult to experiment.
If you are an MC phono fan perhaps you might want to look at Alan Wright's SS phono stage. You can achieve enough gain to do away with a step up transformer and it will fit nicely at the back of your cabinet.
