If you are running audio lines that long you could use low-capacitance composite video cables for long audio links tho' I'd put the amplification nearer the source.
:scratch2: I had no idea I could use those types of RCA video cables. Any idea who has them for least amount of $$. If I purchased these low-capacitance RCA video cables (25 feet long) and then hook the Denon SUT next to the TT the AT- OC9ML/II MC cart, will have a better signal to it??? I can't afford a separate phono pre/amp and separate amp yet for all my analog equipment.
http://www.monoprice.com/products/p...d=10241&cs_id=1024101&p_id=126&seq=1&format=2
Put the SUT at the TT, then the phono pre, then the long cables to the amp. Check out the ART DJ-II for an affordable phono pre that doesn't suck;
http://www.amazon.com/ART-II-Preamplifier-Outputs-Switchable/dp/B000AJR482
long Hot summer here in texas so i am havin big fun when the wife goes to work and I am home along to crank it up some.Now we need to get you a suitable amp for a music-only system based on a pair of the Klipsch, probably the Cornwalls.
Are you electronically "handy"?
Will respond to your PM shortly----.
The magnificent monster receiver, I was given one in pieces a few years ago and finally joined AK to get tips on dealing with it. About oily paper capacitors, they seem to be making a comeback with some a'philes after being eclipsed by polypropylene plastic film types. I have some decisions to make about their replacement in some vintage McIntosh tube amps that I'm refurb'ing for an elderly a'phile.--snip--Your Pio1980 PIO= "Paper In Oil" caps? Or Pioneer? --snip--
How does the Audio Technica AT-OC9/III compare with the SAE 1000LT or 1000E?
Thanks
:thmbsp:
