What do you base this on?Boron is not bright, so you might call it polite, even warm. By contrast, sapphire and ruby rods sound almost shrill, and alloy pipes can sound shouty. Sometimes these attributes add to the experience, rather than detract.
Years of experience listening.What do you base this on?
Shure VMR with OEM Be foil and Jico SAS; Technics 205c with OEM tapered Be and Jico SAS; AT 150ANV with an assortment of needles that fit, including the ATN150ANV, ATN150MLX, ATN540ML and others with different profiles; Grace F9 with OEM Blue stylus, SS Ruby CL and assorted aftermarkets that fit; and a couple of wood bodied Denon DL103, one with the original needle and one fitted with a SS Ruby CL. In every case I prefer the pipes to the rods, but of the latter, the boron rod is easiest to listen to over long sessions.So you had the same cartridge with same cut with different cantilever materials?. Probably family of Jico styli for a Shure or something then.... Jico SAS is the only only I know of with options for so many different materials for the same cartridge
But that is not 'is'.Is ist?
Then check this out:
The ruby/sapphire JICO cantilever variants had higher HF peak vs. boron, same with the zirconium cantilever I have. Both sounded brighter than the boron. The ruby I had was too tight in the body and was stuck in the body. Had to use a pair of tweezers to get it out, so that stylus is smoke now. Have not tried any JICO wooden cantilevers, and will never try either. Sticking to boron. That said, JICO does have variation in compliance, probably by different tension wire setting. This also affects damping of the HF region, and all my boron copies do look different in the 10-20 kHz region.But that is not 'is'.
That is 'was'.
Anyway, without actual published verifyable measurements, or better yet blind listening tests (as I have no idea what bright, polite or warm would measure) the statements made hold little value as it's currently something some guy says somewhere on the internet.
I would say, if they can sell it they will make it. JICO also have cantilevers in various exotic wood materials, and I am guessing that there are a few unique markets (e.g. Japan) where they sell good.Manufacturers chose different materials just for the fun of it.
