Audio Technica VM745xML setup issue
mmcgovarin
Hey all, so I'm having an issue setting up my AT-745xML. I just got it yesterday, got a second table and decided to upgrade my main table cart, and put my VM95 on my table that's going in to the bedroom
I am having sound issues, I don't know how to describe it other then crunchy, static, and distortion.
I first set it up on my "new" table, A Dual 1009SK2, had the issues, fiddle with alignment (I have a protractor), weight set to 2g (confirmed with scale). So I put it on my other table, A Technics SL220, same issues, fiddled for an hour, no changes. The issue does seem to get worse nearer the center of the album.
So I've tried it on 2 tables and 3 headshells, the only thing I can possibly think is that the counter weight on both table is pretty far back, but I honestly have no idea, and I'm hoping someone could shed some light
Thanks
Matt
Two tables, correctly set up, same result. If alignment checks out then it sounds like the cart is the issue. If it's getting worse as you go in maybe you've got the wrong template? Not the most forgiving cut, do need to get it correct. Not much else you can do besides maybe reseat the stylus. Can test the coils. Should agree just fine with the technics.
Counterweight position shouldn't do that, but it's possible you've got a heavier than ideal headshell? Still should not destroy the sound like you're describing.
(...) but I honestly have no idea, and I'm hoping someone could shed some light (...)
From your first pic it would look to me as if the cantilever would point a good bit sideways - in which case one can't exlude, that the cantilever assembly might also be rotated (relative to the plastic holder), so that the azimith as well as the orientation of the two magnets might be off, too.
For verification I'd suggest to remove either the cartridge from the headshell or the needle from the cartridge body in order to inspect it more thoroughly. And if in doubt, you might want to post a straight-down bottom view and a straight-on front view of the cartridge or respectively the needle.
Greetings from Munich!
Manfred / lini
I had the same issue with a new 745. Got in touch with AT and at their direction sent it back. They put it under a microscope and reported that the stylus tip was missing. Sent me a replacement cart the next day. Exactly how a company is supposed to honor the warranty. BTW: it sounds great.
