Hi guys im a bit stuck in designing a crossover
I have a 3 ohm 6w field coil fullrange driver which i would like to match with a Philips 25w 8 ohm woofer
Im using a 25w mono tube amplifier to power them
So i would not damage to fullrange im also using an autoformer in the crossover the af is 2;1 i believe as it reduces 220 to 110 voltage.
I would like the crossover frequency to be somewhere between 350 to 450hz..but using any method i can think of i can not figure how to calculate the design and the filter values
Ps the autoformer shows 10 ohm resistance with a multimeter, the fullrange shows 2.8 ohms and the woofer 6.5ohms with multimeter.
Absolutely any help or advice would be much appreciated
