Autoformer in crossover help needed
pesoo
Hi guys i need help in a crossover design
I have a field coil 3 ohm 6w full range which i would like to match to a 25w 8ohm woofer
Using a tube amp 25w
I ll need to add an autoformer to protect the fullrange alone but the impedence imbalances have confused me
The autoformer is 2:1 as it aas used to reduce voltage from 220v to 110, it shows 10 ohms on the multimeter..the fullrange shows 2.8 and woofer 6.5 ohms
Any help would be much appreciated
I have already purchased a 30uf capacitor and a 3.0 mh inductor but i believe i have made an error in my calculations
