Bert Beukema
Well-Known Member
Hi guys,
First off: i hate modern cassettedecks for servicing. That off my back, on my desk is the old deck from my father. It's a Philips FC-910 double deck with one play and one autoreverse deck. The play deck is doing it's job but the autoreverse deck is faulty. I've changed the belts as a generic measure, doesn't help with the issue. This is a machine that uses a solenoid.
All functions are OK on the autoreverse deck but the actual play function. When one presses play, it will start playing (and produce sound) but after 2 seconds it will autoreverse and play for another 2 seconds. Then it stops. There are no errors on the base voltages; the motors are working fine and everything is lubed and ready to go. There are no broken gears and manually I can move all components with ease. I can see the solenoid moving; not sure if it is moving correctly though.
Troubleshooting is a damn pain on this machine. First off, the PCB that controls most of the motor functions is double sided; with the reverse side all SMD components that are *unmarked*. Yep. No silk screening. I do have the service manual, which is actually superbe. I've added some parts of the service manual as an attachment. As far as I can see most of the circuit involving the deck is on the SMD side.
In no way am I an experienced cassettedeck technician; my forte is on receivers and amplifiers. That said I would like to take a stab at this if the cool cassettedeck guys think there is a possibility of resurrection. That said, I'm not going to spend days with this deck ;-).
Thanks!
Bert
Thanks!
Bert
