Avid 10" Woofer Questions
rl1856
I just purchased a pr of speakers with Avid woofers installed as replacements. Avid woofers were drop in, perfect fit, same screw hole locations and cutout looks like it was made for the Avid driver.
Does anyone know what the specs are for this woofer or the OEM source and model number ?
Web and AK search indicates this woofer was used in the Avid 102, 102a and some 103 models if that helps. I understand the tweeters in these speakers were OEM Phillips.
Thank you,
Ross
i have the 103a avids. great sounding woofers, spl for the system is rated as 87db/1 watt. all i can say .
the philips tweets are amazing.
