Hi,
Sorry to bug you just I had a few follow up Yamaha questions after digging into my CA-610 II and cleaning the pots and switches.
1. Any advice on removing the balance knob?
I completely removed both of the set screws from behind the sub-panel and no matter how hard I pull on the knob it's not budging. Seems like it's putting a lot of stress on the volume / balance pots when I pull on it.
I read a few other AK posts about that knob suggesting the "2 spoons" method but I just wanted to make sure I wasn't missing something else holding it on.
2. I notice a white crust around the output transistors (see attach pic). Is that corrosion and is that normal or a sign of an issue?
If it is normal is there anyway to safely clean that? (my goal being to clean this thing inside and out to a factory fresh look)
3. I checked the DC voltage across each of the output transistors and I got:
transistor 1: 47.3
transistor 2: -14.19
transistor 3: .311
transistor 4: -14.16
So two with a negative value, one very low and the other in the range you had suggested. Does that look correct to you?
The unit has been unplugged for a few days.
Any advice would be much appreciated!
Mark
transistor 1: 47.3
transistor 3: .311
Mark
