JSMATT
Member
Purchased a used B-2101 - did not test it live.
Have recapped and replaced some resistors that had glue for all boards.
First step was to complete the 4618s and set their trimmers, once those two boards etc. were redone. Waited to do the 4619s until the unit worked off DBT which it did. Then I pursued the 4619s with new caps and other updates like thermal paste redo.
Put the unit back together and put it on DBT. Bright light. WTH.
Part of my work on this was redoing all the white thermal paste. That included the double diode sets resting between the power caps.
I undid the big caps - had done that once and thought I bricked them - hence my earlier post on tricks/tips to undo the big caps associated with them. Even with the caps undone, the bulb burned brightly. WTH.
So, I pulled that small board and its tall heat sinks out. And I looked. And looked again. And, finally, saw that a splash of solder had bridged two traces. &$%#!
Reassembled everything again, carefully, and put it on the DBT - bright them dim and that great sound of relays closing. Finally, sorted... or not.
Next steps were to set all the bias etc. to spec. Turned the 2101 on, confirmed vol. pots min and let it sit.
I started with the right channel. All the steps required went smoothly, not withstanding the 4618 'wandering bias' issue that has received attention again on Magnus Black's post. I had set the new trimmers to what the originals were and that certainly saved a lot of fiddling.
On to the left channel. I could set the kVR1 0n 4618 and get it to 0 mV. On may way I thought, tunes in an hour!
I went to set the KVR4 and KVR3 on 4619 - that was a train wreck. Every time I got them set to 6.6 mv, the transistors seemed one step from meltdown, as the heat sink was too hot to touch. Something was very much wrong on this left channel. Right channel Output Hot and Emitter Hot and Output Cold and Emitter Cold were 6.6mv and the heatsink was only lightly warm.
I pulled both new 1K trimmers and reset them to the original pull values. Transistors back to a cool state.
I went through this routine maybe 3 times, pulling the trimmers and resetting them; I adjusted these trimmers a lot (yes, and not keeping sufficient track of the turns, my bad. Violated the take it slow rule.)
I checked the soldering of both the 4619 and 4618 boards and all looked good.
Swapped the 4618 board from the left channel to right, and no issues with the bias of KVR3 or KVR4 - not exact, but close. So, there is no reason to suspect the 4618 is driving the issues on the 4619.
Now, more questions than answers are floating on this ongoing diagnostic session.
I went through the svc man and annotated it to make it easier for me to take measurements. I have attached it (see 2 attachments, PDF was too big to upload) and the actual readings I pulled from it (pls see the two attached tables- the 1st is of the power trans in place and 2nd is actuals for the values from Svc Man.). However, I do not know to what extent kVR3 and kVR4 impact these readings between the two channels.
Does anything stand out, such as the values I have in red? And, what are the suggested next steps for diagnostics? Start removing and testing the smaller transistors?
Any insight would be most appreciated as I am keen on enhancing my diagnostic chops.
Thanks in advance.
Thanks in advance.
