B-2102 hot 24V regulator
Hyperion
Roobarb & Custard
I have been thinking for a long time (too long) what to do about the 24V (µPC7824H) regulator in my B-2102 which simply gets too hot in my opinion. The heatsink is too hot to touch after about 15 minutes, and the radiated heat threatens to 'cook' the Left Channel driver board. I checked the input voltage was within spec limits and it was, I also checked the current through the regulator - well within limits.
I changed the regulator for a new one, same problem. A way to reduce the heat is to reduce the input voltage, but this could cause regulation issues, and there is very limited space to mount a larger heatsink. I thought about mounting the regulator remotely from the PSU board on a bigger heatsink, and even thought of putting it on the left channel main heatsink. Both of these ideas have drawbacks too great for further consideration.
I had a careful look at the currently available PCB mount heatsinks looking for a bigger (taller) replacement - tough job. Eventually I found one which is 25% bigger and is also black anodised, the original is plain aluminium. I also bought another one (bigger, which only just fits), in case that wasn't enough. So I was thinking, "what if neither of these results in an improvement"? So plan "B" would be the inclusion of a rectifier diode in series with the feed to the regulator to cut the input voltage by 0.7V - this was about as much I felt I should reduce it by.
I am pleased to report that the combination of the new heatsink and the series rectifier diode have provided a most satisfactory solution to the heat problem. The heatsink is warm, but never too hot to touch, and the 24V regulation is fine. (input voltage is now 28.7V, regulated output voltage 23.7V).
LED's for the power meter backlight?
In parallel with this I was trying to implement the replacement of the 6 incandescent power meter display backlight bulbs with LED's - but after trying 3 or 4 different ones, and never getting an even spread of light, I bought some replacement standard bulbs and I am happy with the end result.
So, I can now get on with other stuff, knowing the B-2102 won't cook itself. :)
Thanks for the detailed evaluation of the regulator heat issue. This is something that I will include when I finish the restoration of my 2102.
I tried the same thing with the meter lamps, and ended up with incandescent bulbs. I used 12v 90ma as these were readily available (rather than the 12v 75ma originals)
Cheers
John
Thanks John, another way to reduce the input voltage is to increase the value of the series 4.7Ω resistor, but that just adds to the heat around there, so the rectifier idea seems best. ;)
Pretty cool idea John. About incandescent bulbs , I tried some leds on my 2301 and had the same type of problem. Ended up using classic light bulbs.
Good to see something on the 2102. I have one in my shop with a bad right channel; low volume and goes into protect when volume is turned up. I plan to create a thread on it after I work through a couple other problem units.
Thanks!
Thanks for the support gents!
It may be a few weeks until I get the the bit B-2102 as I'm still trying to figure out that instantly-closing relay issue on the AU-7900 for which I have a thread.
New here, but I will be watching any updates here with interest. The B-2101 I have suffers from the same problem.
