Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
The SE-100 is better than the BK pro 5, is cheap but very good
The Iris and the 915 have the same topology, but the Iris has the tendency to fail do to the Tantalum caps
The B&K Pro 10 and Sonata have better build quality, but the Iris and 915 sound better
Yes I do have all those preamps
I also have the Adcom 565 and is not as bad as the review, sounds really good too
The Citation 21 has a better line stage than any of all the preamp mentioned in the review
The problem with the Halfer is that they are too old, they are going to need a restoration, in addition
the DH-200 and 220 are around same power as your BK, unless you go for a DH-500.
I bought this DH100 to digitize my LPs. I needed a phono stage and the ability to control the output to my Analog-to-digital converter. It worked for a while but I wasn’t happy with the sound. I looked into the DH100 and discovered it was a series 1. And there was a series 2. Could this be the...
The DH-110 replaced Hafler’s first preamp, the DH-101, and was produced from the early 1980’s to the early 1990’s. I picked up this unit and decided to look inside and upgrade it. This unit has everything. A headphone amp that’s not very loud. A muting circuit to prevent downstream thumps that...
