Thanks for the additional info,
I doubt a clean cutoff in sound is caused by capacitors, so it's amplifier diagnostic time there may be sticky threads on this.
Is there a protection circuit usually operated by relays, do you hear a click at turn on, has it clicked out when it fails.
Is there a break in signal, check cables, connectors, tap components.
Is anything getting hot.
Is the power supply still supplying volts. Are there any test points you can check probably indicated on the circuit diagram or pcb.
Trace the signal back to the point of origin as best you can, at the very least you'll need a multimeter on ac volts.
Lookup heatsink thermal pads for replacing the pad it probably is the place to separate, it might come apart intact perhaps with some iso, or might rip or loose adhesion, or you might need a setting thermal compound to reapply.
