crazy-in-az
Uhhhh....
I bought this amp about three weeks ago, and until last night it has been flawless.
Last night I turned it on following the proper order of pre-amp first, then power amp. As soon as a I tried playing a record I could hear a fuzzy sound coming from the left speaker, and the volume was fluctuating rapidly. I also could visually see the woofers on my Marantz Imperial Six's pumping in and out, as though there was some bad feedback from my turntable. The right speaker doesn't seem affected.
Here are are the things I tried-
-I swapped sources to my Technics CD player
-I changed speaker wire
-I tried different speakers
-I swapped interconnects
-I tried the amp on both outputs from the pre-amp (a Nikko Beta 30)
-I exercised all the buttons and switches on the pre-amp
-I tried to clean the amplifier control muting switch with deoxit
-I tried the same record and same turntable on the Nikko with a different amplifier and there was no distortion
I'm guessing something else is going on, something that requires more than a cleaning or swapping of cables. Outside of a complete overhaul can anyone give me some pointers or ideas?
