Couldbfishin
Couldbfishin
A few months back I bought a used set of B&W speakers. This included 805 D2 bookshelf or stand mount speakers, a center speaker and a powered sub-woofer. I also bought with the package a McIntosh C34V pre-amp and the seller threw in a Denon 110 watt 7.1 AV receiver. I think the seller had used a McIntosh MC2500 (500 wpc) amp with this system, that I missed out on buying.
I have since had Audio Classics bench test and restore the C34V pre-amp and purchased from them a MC452 amp, to use with JBL L150s as my main stereo system.
One of my 40" TVs died and I replaced it with a 65" Sony A8G UHD 4K TV. The picture is phenomenal by the way, and the sound comes through the screen and isn't bad either.
But, I want to use the B& W speaker system as a front sound system. I have set it up with the Denon AV receiver and it sounds ok, but doesn't knock my socks off. I have been told the Denon AV receiver is not that great and a McIntosh separates system would make a world of difference using the B&W speakers.
I was very impressed with the difference switching to McIntosh separates made in the sound of my stereo system, with my existing speakers. I am thinking I would like to hear McIntosh gear for my AV system with the B&W speakers.
I have a small budget after buying a new TV and the MC452 this past year. So I have been reading about the C39 pre-amp and the MC2205 amp (200 watts x 5 channels), for about $3000. Someone selling a MC2205 suggested that I bi-wire the 805's and single wire the center speaker. Does that provide 400 watts to the two front speakers and 200 to the center? What about the powered woofer? If I was going to consider doing that, couldn't I just try my C34V pre and MC452 temporarily, to see how I liked it? Would that basically be the same sound?
Ok, enough background information. What models McIntosh pre and power amps would you suggest I consider? I am thinking 200 wpc or better, as the B&W speakers are rated at 200w conservatively. And, if I don't use back or overhead speakers, how many channels do I need?
The B&W powered sub-woofer is intended to split the two channel stereo signal coming into it by frequency among the front, center and sub-woofer. Is there a downside to having the sub-woofer split the signal instead of it being done by the pre-amp? If no downside, could I just buy a stereo pre-amp and amp, and split the two channels with the sub-woofer?
Thanks,
Couldbfishin
Thanks,
Couldbfishin
