Stevemaine
I've got them completely torn down and going through everything. Lots of fluffy white corrosion on the speaker frames (all cleaned up). I think I'll clean the contour pots and all connections, and probably bypass the fuses. My knowledge on crossovers is just about zero, but these look a little different than any of the pics I've found on line (everything is dated 1979 on mine). Both boards show signs of heat around some on the components (see image), but I checked ohms (with parts still on the board) and everything matched between the two boards. I don't know if they just got overheated once, or if stuff is burned up and need to be replaced. Just some darkening of the board around the white ceramic things... I tested the ohms on both tweeters and they match at 5.9 ohms.
